Fuel shutoff
Rob N VA
03-04-2005 20:09:04
For the longest time I haven't been in the habit of shutting off the fuel shutoff valve, until I started reading here. Now I am in the habit of shutting off the gas and letting the carb run dry until it stalls, and then cutting off the key. Logically, I figured this was the way to go, but it makes it real hard to start the next time, especially if its cold. Do you guys drain the carb like this (by running it until it stalls)? Or is this bad? What is the best way to go?--Rob
Dean
03-05-2005 04:53:53
 Re: Fuel shutoff in reply to Rob N VA, 03-04-2005 20:09:04
I run mine dry every time unless I am certain that I will be starting it again soon. Otherwise I may not start it for some time and gasoline evaporates quickly the days leaving varnish.
Dean
Ramrod
03-05-2005 03:54:58
Shut it off when you shut it down. Shut it off and run it dry when you put it in storage.
Ramrod
ButtonRock
03-05-2005 02:31:28
I always shut the fuel off and never run it dry. Starts right up and I do not lose any fuel, its too expensive to waste.
Hi, Rob..John,PA
03-04-2005 20:24:10
I really don't think runn'n the carb. dry is necessary each time you want to shut-down the engine. Turning off the fuel valve is still a good practice, though. Since I am blocked from the Forum, I just cheat a little on AOL.
John,PA
fredhead
03-04-2005 20:35:22
 Re: Fuel shutoff in reply to Hi, Rob..John,PA , 03-04-2005 20:24:10
why did you get banned from the discussion board.
Don't know..
03-04-2005 20:45:44
 Re: Fuel shutoff in reply to fredhead, 03-04-2005 20:35:22
Must have been petitioned for writting instead of just monitoring. I don't think I really DID ANYTHING BAD, though. I tried to find out, but the management refused to tell me. SO, I QUIT.
Been restoring a house in OLD PENSACCOLA, FL. Was just taking a break from the job site, from time to time. I hope this message gets to YA.
John,PA
Tom
03-05-2005 00:49:22
 Re: Fuel shutoff in reply to Don't know.., 03-04-2005 20:45:44
Sounds like you are back on your medication!! Keep up the good work..
