Rear Scoop
CraigNAA
03-05-2005 21:18:09
Hi all,Is a rear scoop worth while? I have some dirt to move,They seem to come in 24 and 30 "
Any one better than the other? And what brand?
Needs to be well built. Thanks ..Craig
CraigNAA
03-06-2005 11:49:43
 Re: Rear Scoop in reply to CraigNAA, 03-05-2005 21:18:09
Thanks for the response Farm & Fleet has a King Kutter 30; for 260 I will check it out. Craig..... .
Dave 2N
03-06-2005 07:41:41
I have two rear scoops: a Dearborn that I've restored for shows and parades and a more modern one that I use all of the time. There's not enough time in eternity to tell you all of the things I use it for.
( Pics) Ken N Tx
03-06-2005 01:12:40
 Here is Mine in reply to CraigNAA, 03-05-2005 21:18:09
Would not be without onethird party image
third party image
third party image
jhill
03-05-2005 22:45:56
I have a Ford scoop. Mine only works going forward. Its great I have moved alot of dirt with it.
Mike S
03-06-2005 04:22:02
 Re: Rear Scoop in reply to jhill, 03-05-2005 22:45:56
You sure? I have a Ford scoop and it works in both directions. Mine was made in the 70s, I think. I forget the model number. Maybe older ones only worked in one direction. But it sure is handy for everything like moving dirt to hauling firewood. I had 15 tons of chippings dumped at our old house and the guy refused to back down to where I needed it so he dumped it in our side yard and I used the scoop to move it all the other 100 feet. Took a couple of hours but was a lot faster than doing it with a wheelbarrow.
souNdguy
03-05-2005 21:36:08
30" works good. As for brand.. Me.. I lok for something fairly cheap. They are pretty much bullet and idiot proof.. and even the economy models are built like tanks. I have the KK 30".. works great and I've moved dozens of CY of dirt with it.
Howse makes a good looking one too.
Soundguy
Scooper
03-05-2005 21:51:24
 Re: Rear Scoop in reply to souNdguy, 03-05-2005 21:36:08
Also have a KK 30" scoop. Although they can be used both forward and backward, I prefer forward. After a couple of scoops I figured out that a well placed bungy rope and a well placed nylon rope helped in both cutting deeper and releasing or dumping the bucket load while moving forward. This worked much better than the regular setup. Takes about half an hour to become very efficient with the added rope/bungy cord "controls".
Benjamin
03-06-2005 07:02:25
 Re: Rear Scoop in reply to Scooper, 03-05-2005 21:51:24
great info and pictures shared here. Never knew you could move dirt or what the name of one of these was. Still learning, and you guys are the best teachers in the world.
keep the info coming!
thanks
Ben
(the info hogg)
