domed pistons?
BOB061
03-18-2005 18:11:16
I have an opertunity to get a set of domed pistons for my 8N. Would appreciate any input of pro"s and con"s in doing this. I am going to rebuild anyway and just want to know if it will make much of a difference good or bad. I"m sure the increased compression translates to some extra power but will this cause extra stress to the lower end and starter?
Kelly Jewell (KY)
03-18-2005 20:15:01
 Re: domed pistons? in reply to BOB061, 03-18-2005 18:11:16
Bob, are you referring to the super power kit that was available years ago with the deflector on top of the pistion? These will work. You could use a glob of play dough on top of the piston, bolt the head back on with the head gasket, remove the head and measure the play dough. Also, there has always been two head gaskets available 8N6051A and 8N6051B and there is a different thickness in the two.
ZANE
03-18-2005 18:34:13
The N piston is domed to begin with in the standard piston and it will not stand any more dome than the standard dome. Even the standard domed piston has been known to hit the head if over about .020 is taken off the head.
Zane
BOB061
03-19-2005 06:22:06
 Re: domed pistons? in reply to ZANE, 03-18-2005 18:34:13
Thanks for the advice. May have saved me from yet another costly lesson.
HOOKER
03-18-2005 19:33:35
hey zane i cracked two pistons when i took .006 off my head... at that piont in time i knew somebody has shaved that particular head several times,,, thats the problems you run into buying a used head
USED HEADS ARE BUYER BEWARE PRODUCTS
a very expensive lesson to learn
jake
Roughstock
03-18-2005 19:22:20
Never mind. Zane already answerd my question.
Roughstock
03-18-2005 19:18:21
What are we considering Domed Pistons because when I had the head off mine the other day they were all identical. There was a slite dome affect to all of them. Is this not standard? Would the normal pistons be flat on top? If so then I guess I have domed pistons.
