Your main problem is not where the fill plug is but how to install a new upper sector thrust bearing. These Ford tractor steering sectors have a built in flaw in that the top thrust bearing is never oiled unless the box is overfull and the top thrust bearing is the first thing to go. Once the bearing is run without lubrication for long enough no amount of lubrication is going to fix it so it steers good to the left again. It is going to have to be replaced. STEERING SECTOR REPAIR The steering sector shaft bearings are gone bad along with the one you can see on top. The one on top under the steering wheel is not the one that is causing it to be hard to turn however. There are two bearings on the sector shaft itself. One at the bottom of the sector and one at the top of the sector. This is the part that is in the steering box that moves the two pitman gears that move the two pitman shafts that move the tie rods. You will have to remove the steering wheel. Then the hood. Then the battery box and the steering box and dash support along with all the wires etc that may keep you from being able to pull the dash from the steering sector assembly. It is best to take the steering box completely off the tractor so that it can be cleaned good and be sure that all the old broken bearing parts are removed from the housing. Replace both the bearings and the bearing cones. Don’t let anybody sell you on using the Nylon replacement bearings. They are no good and it will still take both hands to turn the thing after you re assemble it if you use them. Use only the ones made of steel that are designed for the Ford steering sectors. When you re assemble the assembly you should fill the whole sector with grease and not oil. The top bearing will always be the one that fails because it never gets any lubrication if it is filled with oil. The filler hole in the steering should have been above the bearing for it to have been awash in oil all the time like the bottom bearing is. You can drill a small hole in the sector shaft housing just under the steering wheel hub and pour oil into the sector and onto the top bearing if you think it is necessary. Pouring oil down the hollow shaft will not put oil on anything but the hollow shaft as it is not open at the bottom. If you don’t take the two pitman gears out of the sector you won’t have to worry about timing them. If you do remove one or both you will have to be sure that they are properly timed to one another upon re assembly. The sector gear must also be timed to the pitman gears. If you play with it and observer the relationship of the gears you can get it back in time before you put the sector shaft cover back on top and torque it down. Be sure to check it for proper timing before you put it all back together on the tractor. Zane
