I had that problem with a new radiator.
Rob
03-21-2005 07:49:25
Turn out the axle support was distorted and bent up. I set it level and measured up to the radiator supports and had to bend stuff around to get them the same, plumb and level. I laid a straight edge across the the front of the axle support and it was bowed out so I straightened that. I fussed with it (heated, banged, and wailed on it) until I got it squared up all around. Pretty much anyway.
That axle support gets distorted then the axle might hit the radiator (ruins it with core leaks near the lower hose bib) and the front-mount distributor cap (breaks the nipple off), the fan might hit the radiator overflow line, the shroud won"t clear the fan so the shroud is probably missing, and the hood doesn"t fit right so you can hardly get the oil filter cartridge out.
Other than that it"s not a real problem.
