Hard to know why it boiled over after running
Rob
03-21-2005 10:56:13
fine for 3-hours only weeks before. Maybe you had the brake set. Maybe you blew a head gasket.
Do you smell exhaust in the radiator? Did you retorque the head after running an hour or so? You might retorque if you haven"t. And remove the water down to the radiator core. And not a cup more or you will just complicate matters because she will spit out any excess and you will imagine it"s "boiling over."
So retorque the head, get the coolant level correct, make sure you release the brakes, and see what happens next time.
Rusty8N
03-21-2005 13:04:21
 Re: Hard to know why it boiled over after running in reply to Rob, 03-21-2005 10:56:13
Thanks Rob...I did retorque the head bolts after an hr...this was before the successful 3 hours of mowing...the latest boil-over was while idleing in the barn, so no issue of brakes...the only sign i know of blown head gasket is water in oil, is that correct?? Don't see any.
I will follow your advice, once I get her running again, thanks.
Rob
03-21-2005 14:02:52
 Boiled over at idle. Is the radiator plugged in reply to Rusty8N, 03-21-2005 13:04:21
with grass and weed seeds in the fins? Mowing grass and weeds taller than axle high will do that. You can wash it out or blow it out with air or both. You should be able to look through the radiator and see your hand moving on the other side.
Check the belt tension. 1/2" movement half way between the crank pulley and generator. Put both hands on the genny pulley and try to turn it. It shouldn"t slip.
Sounds like you aren"t moving air across the radiator when it"s sitting still.
Maybe it"s a thermostat problem but I don"t know that it could be.
jiminoystercreek
03-22-2005 03:05:23
 Re: Boiled over at idle. Is the radiator plugged in reply to Rob, 03-21-2005 14:02:52
I like Rob's answer here. I've had this happen to me (Plugged radiator from weeds/seeds).
I'm curious if you can see water circulation or movement in the radiator prior to the boil over incidents, indicating a functioning water pump and thermostat.
I'm thinking that maybe if its a water pump/thermostat issue, when the water in the block gets real good and hot, its popping the thermostat and dumping real hot water into the radiator, where it quickly forms steam- resulting in boil over. Just a thought.
Rusty8N
03-22-2005 07:28:12
 Re: Boiled over at idle. Is the radiator plugged in reply to jiminoystercreek, 03-22-2005 03:05:23
There really may be something to Rob's answer....the 3 hrs mowing with no over-heating ended up with cutting some high weeds pretty near the end....the rad was covered with thistle ....I brushed the visible stuff off, but did not check if all the spaces between fins are now clear...great detective thought...thanks, I'll let you know...
Rusty
