Control valve - Pump
Young9N
03-22-2005 19:01:54
I broke my control valve and have purchased a new one(thats what happens when dad knows a faster way to remove the lift cover). The valve came with Two springs that connect the yoke to the lift cover. Do I need to install both springs?
What is the corret direction to install the yoke?
(it can be installed either way but one direction FEELS better)
Do the lift arms raise when the control valve is in or out?
Thanks in advance
Rob
03-23-2005 04:14:02
 Mysterious. in reply to Young9N, 03-22-2005 19:01:54
You talking about a 9N? I don"t see what you"re talking about. The control valve is down on the belly pump and I can"t imagine it comes with two springs that connect the yoke to the lift cover.
Young9N
03-23-2005 07:44:58
 Re: Mysterious. in reply to Rob, 03-23-2005 04:14:02
Yes the tractor is a 9N.
The spring(s) in question run from the Control Valve Yoke(not sure correct name) to the bottom of the lift cylinder which is attached to the lift cover. When the spring is in position it has NO tension and tends to fall off (shouldn't it have tension and help hold the control valve in the pump?).
Rob
03-23-2005 08:25:33
 Ok, there's that 'fork retracting spring.' in reply to Young9N, 03-23-2005 07:44:58
Something must be worn or adjusted wrong for it to fall off. Maybe the control arm (yoke) is moving too far forward. Not sure what would allow that to happen. The arms should be straight. They have a dogleg in them?
Do you have the big control spring and yoke mounted out the back of the lift cover? Seems that holds the plunger coming off the control arm and without it maybe that control arm moves.
I"m just working off the drawings but maybe Zane the hydraulic guru or another has seen that situation. Zane has posted lately and you might respond to one of his posts so he gets an email alert.
