Ok, there's that 'fork retracting spring.'
Rob
03-23-2005 08:25:33
Something must be worn or adjusted wrong for it to fall off. Maybe the control arm (yoke) is moving too far forward. Not sure what would allow that to happen. The arms should be straight. They have a dogleg in them?
Do you have the big control spring and yoke mounted out the back of the lift cover? Seems that holds the plunger coming off the control arm and without it maybe that control arm moves.
I"m just working off the drawings but maybe Zane the hydraulic guru or another has seen that situation. Zane has posted lately and you might respond to one of his posts so he gets an email alert.
