Order Ford 8N Parts Online
8n tractor
BBWill
04-27-2005 18:49:50
i want to know if the yoke attached to the shaft that comes out the back of the tractor is supposed to fit snug or loose.
Dan
04-27-2005 18:57:25
 Re: 8n tractor in reply to BBWill, 04-27-2005 18:49:50
Snug, but not too tight. You should be able to twist it wit some force. It is only used with draft control, so unless you do a lot of tillage work, it is not an issue if it is loose.
Good luck,
Dan
