Order Ford 9N Parts Online
2N or 9N
BOB061
05-04-2005 15:07:44
Well, while looking for a set or rear tires for my 8N I ran across a deal on a whole tractor. I know it's either a 2 or a 9 because of the 3 speed trans and the wheels but what clues do I look for to find out which it is. The fella I'm buying it from said he was told it was a 2N because it has a 6 blade fan and a shroud. Is this an indicator? It has tubular radius rods also. Going to pick it up Saturday so I will be able to check better then. The engine serial number is unreadable. Thanks in advance for any help.
Patrick/N-Tiques/OR
05-04-2005 16:40:21
 Re: 2N or 9N in reply to BOB061, 05-04-2005 15:07:44
In addition to Jeb's reponse, check the serial number of the block. Once in a while, someone has changed the block, but it is a good way to tell. Here is a link...
Link
Good luck!
P
Jeb2N
05-04-2005 15:19:51
Well, the radius rods were changed in 1944 and anything with tubular rods originaly would have been a 2N or 8N, but they're easy to change out. The 9N's generally had the aluminum parts, but look for any parts that have 2N part numbers cast into them like the axle trumpets, or the casting code on the starter bulge.
