Choke plate return spring picture
Rob
05-10-2005 15:34:42
third party image
6N's Short
05-10-2005 16:10:17
 Re: Choke plate return spring picture in reply to Rob, 05-10-2005 15:34:42
Thanks Rob! That looks about right and I can see I have it put together OK. I am a little puzzled by the spring hooked over the choke arm on the outside of the carb. I don't have one of those.
Must be with the missing packing, missing washers, and the missing heaven knows what else.
Is this something I need to find? I doubt it's in the basic rebuild kit.
Rob
05-10-2005 16:32:09
 Re: Choke plate return spring picture in reply to 6N's Short, 05-10-2005 16:10:17
The choke return spring that hooks over the arm on the outside returns the carb to "no choke" when you release the choke knob on the dash. Pull the choke knob it chokes the carb, release the knob it returns to no choke. You want it to happen that way and that spring is more than handy. I"ve wedged the arm pushed against the spring to move the plate into the full choke position. I don"t remember that spring in the kit out of TSC, in fact I remember it wasn"t in the kit.
Dell (WA)
05-10-2005 17:01:46
 Re: Choke plate return spring picture in reply to Rob, 05-10-2005 16:32:09
Excellent picture of the M/S carb strangler plate (choke) The choke return coil hairspring is Ford p/n 9N-9539 and is listed as being available as part of the "BIG" rebuild kit. Also available seperately. The WHITE FELT packing (seal) p/n 8N-9689 goes between the coil spring and the carburator casting on the choke shaft. ..... ..Dell
6N's Short
05-10-2005 18:29:04
 Re: Choke plate return spring picture in reply to Dell (WA), 05-10-2005 17:01:46
Thanks guys! You are right, Rob, I have the kit from TSC now and it is not in it. I'll call my NH guy tomorrow and ask about the part. See if it is in stock. I imagine my local hardware has something similar but I would be hard pressed to tell them what size I need. I sure hate to drive all that way out to the dealership again. Appreciate the parts numbers, that will be handy when I call tomorrow. If anyone has an idea for a generic from the hardware, I'd love to hear about it.
