govenor
BOB061
05-22-2005 04:49:20
I am swaping my 8N side dist engine with a 2N front dist engine. Can I swap out the govenor to continue using the proofmeter or is there more to it than that?
Jeb2N
05-22-2005 05:14:46
 Re: govenor in reply to BOB061, 05-22-2005 04:49:20
The throttle control linkages that control the governor are very different on the 8N and 2N. I would have to look hard at the two setups to see if they would be compatible with each other. Probably won't have much difficulty, but just look at it before hand and know that there is a slight bit more to it than that.
Jeb
BOB061
05-22-2005 05:18:53
 Re: govenor in reply to Jeb2N, 05-22-2005 05:14:46
Thats the other reason I want to change over the govenor, so all my 8N linkages still work.
Jeb2N
05-22-2005 05:23:56
 Re: govenor in reply to BOB061, 05-22-2005 05:18:53
Except for the differences in the arms, linkages, and the proofmeter drive, it all goes on the same.
Jeb
