headgasket
BOB061
05-22-2005 15:34:49
I am getting ready to order my parts to swap my engine and convert to 12 volt on my 8N. The motor I am installing had been sitting for several years. I did have to squirt a little oil in the cylinders to get to fire up. It was full of antifreeze with no leaks. I ran for a good 20-30 minites with no trouble. Should I replace the head gasket because it sat so long or give it a try. I think the engine has been rebuilt, I just don't know when. I just want some advice from you more experienced many here. Thanks
old
05-22-2005 18:55:55
 Re: headgasket in reply to BOB061, 05-22-2005 15:34:49
Well if it where me and it had sat for a year or more, I'd fill each cylinder with tranny fluid, go to bed and then the next day pull the plugs and spin it over. It can/will make a mess but it will also loosen up the rings valves. It will smoke a lot for a few minutes but that will clear up. The head gasket should be good. Shoot I have one tractor that had sat for 15-20 years and was stuck and I haven't ever had the head off, and my son drove it in a pradade of power last fall. I also know the rings in that tractor are at least 50 years old. It was my grandfathers tractor.
Russ SoCal
05-22-2005 21:11:51
 Re: headgasket in reply to old, 05-22-2005 18:55:55
old,
Why would he put anything in the cylinders and let it sit? He already ran the engine for half an hour.
Russ
old
05-22-2005 21:17:29
 Re: headgasket in reply to Russ SoCal, 05-22-2005 21:11:51
Well he said he had to put oil in the cylinders to get it to start which to me says low compression/stuck rings. And I have found out the hard way that stuck rings can mean a broken ring if you aren't careful.
Tom in MS
05-22-2005 16:04:32
Others with much more actual experience with these old flatheads will chime in but I KNOW what I'd do.....Fire it up and run it and never look back..... ..... ....
