PTO Clutch
( Pic ) Ken N
06-04-2005 01:15:15
Answer to previous post.
( Pic ) Ken N Tx
06-04-2005 01:18:24
 Re: PTO Clutch in reply to ( Pic ) Ken N Tx, 06-04-2005 01:15:15
Posted by KCM on June 03, 2005 at 20:36:22 from (67.0.21.183):
In Reply to: Re: Live PTO 9N posted by Jeb2N on June 03, 2005 at 17:23:51:
I once saw an 8N with what could be considered a live PTO. It looked to be a clutch pack between the transmission and rear end, and was released by moving a lever that came out of the PTO lever cover. It really wasn't a true live PTO, as it simply stopped the tractor from moving by adding another clutch after the transmission. I'm not sure, but I think it was made by Sherman. Sherman did make hydraulic-controlled units for the Jubilee/NAA, same idea but they used a small hydraulic pump added behind the main lift pump to assist the actuation. Have seen a couple of those as well.
If you want a live PTO, best to buy a newer Ford with it built-in.
third party image
