I still do not have spark at the plugs. I have been over this thing 9 ways from Sunday, but still can't figure this thing out.1. I went back to the old round can coil configuration I had when I bought the tractor using a *cobbed* up square coil to cover the distributor and make contact with the points and distrib cap. 2. I removed the distributor and tested continuity from the point terninal screw across the points when they were both open and closed. Just to make sure there were no *shorting* issues. 3. I ran a wire from my *new* ignition switch to the pos(+) side of the round coil and a wire from the neg(-) side of the round coil to the terminal on top of the old square oil. 4. I put in a new coil wire coming out from the square coil to the round coil and tested all contacts (points and cap) for good continuity. 5. I bought a new set of wires, cut them to fit and tested contacts for continuity. 6. I have ~10 V at the coil when points are closed, and ~7 V when the points are open. 7. Installed new battery cable terminals. I took one of my new wires and hooked it up to one of the nipples on the distrib. cap, and inserted a new spark plug with a wide gap. Placed the plug near a good ground spot on the tractor. But when I cranked the engine over, no spark. I'm stumped and starting to grasp at straws. Think'in about installing a Petronix electronic ignition kit to elimiate the points from the equation completely. Don't know what to do. HELP!!!
