Battery not charging
Rob N Va
06-17-2005 07:09:24
I had my 3+ year old battery go dead in my sidemount 50' the other day. I figured that it was just old. Here's what happened; I was hogging the pasture when she stalled (ran out of gas). When I turned on the reserve, she would barely turn over. I went back an hour later after getting gas and lunch and she fired right off. I brought it back to "sick bay" and charged the battery overnight. Battery now reads 6.25 volts. The Generator is putting out over 7 volts. So now I've narrowed it down to the voltage regulator, or just an old battery that won't hold a charge. How do I know the difference? The voltage regulator is a year and a half old, so I am assuming the battery is the culprit, but I want to be sure. What do you guys think?
As always, thank you for your time!!!!
---Rob
souNdguy
06-17-2005 13:06:43
 Re: Battery not charging in reply to Rob N Va, 06-17-2005 07:09:24
If you start it up, and then you can read 7+ volts ont he battery.. the genny is doing it's job.. I'd do a SG test ont he battery..
Soundguy
Bryan in WI
06-17-2005 08:59:30
I think that you can test for this by starting the tractor, then pulling off one of the battery connections (get it loose first before you start). If the tractor keeps running your generator is OK and should be charging. Dont" make a big spark and blow up, wear saftey glasses. This is how I diagnosed my last bad battery; tractor ran fine with the battery disconnected so that meant that my generator produced enough current to charge the battery. Not sure that you can really tell from the voltage with the battery connected; a bad battery could pull that down.
Lytemup
06-17-2005 08:58:28
You could take the battery to a local shop and have it tested under load. I didn't think a 6V battery with the engine off should read much more than 6.25V you are getting...does it turn the engine over? Just a click? How many volts do you get at the starter with ignition on and when the starter button is pressed?
WV8N
06-17-2005 07:42:01
Have you checked your belt for tightness could be slipping under a load and not charging correctly. My generator loosens up quite frequently
