New to me 2N
BOB061
06-23-2005 16:05:30
Well I split up the recently aquired 2N. Found to have a sherman step up and a howard reduction in back. Does this sound like a common set up? Looked to have a loader on it at some point in time. Are bearings available for the howard units? This one will be a challenge to get going again. After sitting 15 years has a lot of frozen up parts.
Jeb2N
06-24-2005 05:38:28
 Re: New to me 2N in reply to BOB061, 06-23-2005 16:05:30
Well, the shermans are fairly common. The more uncommon shermans are the cable shift ones and the over/standard/under shermans are the most desireable of the 3 (overdrive/std, underdrive/std, and overdrive/std/underdrive).
The howards were designed for use with one implement, the Howard rotovator tiller. They are pretty fragile and are prone to breaking gears. It is generally suggested to not use them as you can't hardly even find bearings for them anymore, much less gears. They are pretty uncommon if not rare. Restore it, keep it in there and it adds a lot to the tractors value, but I wouldn't suggest actually using it for work. If your tractor is a work tractor, I might recommend removing the howard and selling it to a collector so it won't get damaged and you'll still get your money for it. Having said that, i'm not looking for one, just suggesting.
Jeb
