Battery not charging on 6volt sidemount 1950 8N. It should be simple to figure out what has gone wrong, but questions keep poping up. First of all, I seem to have misplaced my fo-4 manual, so if you guys could please give me a quick rundown on where to put the test leads on the multimeter to on the genny, I would appreciate it! Secondly, I had the genny rebuilt last year and replaced the voltage regulator as well as a complete rewire. All that seemed succesful, as I have had no problems until now. I charged the battery and went out to hog the pasture tonight. It started getting dark so I turned on the lights. Five minutes later she started missing and the lights started getting dim (DUH!). I shut the lights off and limped back to "sick bay" in the dark. Before I shut it off, I measured the battery and had 6.02 volts at 1/2 throttle. When I turned the lights on, the voltage started dropping rapidly until I thought it was going to stall, and I turned the lights off, and the voltage jumped back up to 6 volts. Now here's where I start second guessing myself. I know the battery is the oldest component, so I am inclined to think it is just not holding a charge anymore, but wouldn't the reading at the battery be much higher with the tractor running regardless of a dead battery? I am thinking the genny output should be in the neighborhood of 7.5 volts or so, is that right? Sorry for the long post, I just wanted to give good details so you guys could have a better idea of what to suggest. As always, I really appreciate your taking the time to give some advise! Rob
