Rob..... ...thats the trouble, the Bendix is designed to extend into the flywheel ring gear. That is the ONLY direction the starter motor can move the Bendix screw; INTO the flywheel ring gear. Doesn't matter iff'n its a suck'em into from behind the flywheel, or push'em into from infront the flywheel. When the engine starts, its rotational velocity is greater than the starter motor rotational velocity, therefore the starter Bendix "UN-SCREWS" from contact with the flywheel ring gear. Running a starter motor in "free-air" DOES NOT RETRACT the Bendix screw ...EVER... Understand? Remember, no-matter what the battery polarity, the starter motor ALWAYS turns the correct direction to ENGAGE the Bendix screw. And the running engine ALWAYS turns the correct direction to dis-engage the Bendix screw. And YES, Bendix drives MUST-BE SQUEEKIE CLEAN. I use acetone or spray brake-cleaner. WD-40, kerosene, mineral spirits, Stoddards, MMO, all leave "deposits" and will gunk-up yer Bendix screw..... ....respectfully, Dell
