Order Ford 9N Parts Online
FORD 9N SHIFTER BOOT
BIGMOE
08-21-2005 20:15:23
I OWN A 41 9N AND RECENTLY HAD TO REPLACE THE GEAR SHIFT BOOT. THE ONLY PROBLEM IS I CAN'T SEEM TO GET THE NEW BOOT TO SLIDE OVER THE KNUCKLE WHERE THE SHIFT GOES IN THE THE TRANNY. ANY SUGGESTIONS WOULD BE A BIG HELP. THANKS
walt (l.a)
08-22-2005 08:19:36
 Re: FORD 9N SHIFTER BOOT in reply to BIGMOE, 08-21-2005 20:15:23
turn boot inside out. spray with (wd.40) put small hole on shifter first.roll large over boot.
Bob
08-21-2005 20:52:36
Type "shifter boot" into the search box at the top of the page. You'll get about a jillion pieces of "sage advice", from hot water to K-Y Jelly!
Jeb2N
08-22-2005 05:08:54
 Re: FORD 9N SHIFTER BOOT in reply to Bob, 08-21-2005 20:52:36
I was working on mine in the winter time and happened to have an electric space heater in the shop. I sat the boot in front of the heater for a couple minutes to soften it and it went on. I didn't say it just slipped right on, i still had to tug and push a bit, but it did go on. After all, you want it to be tight to help keep the water out of that tranny.
Jeb
