Voltage regulator woes resolved
Rob N VA
09-14-2005 18:51:41
First off, thank you Dell! I tried and tried to polarize the old V.R. and finally gave up and replaced it. Problem solved. I took the cover off the old VR and I don't see anything that looks out of place, or burned. The contact points are smooth and freely moving. I am gonna ask a loaded question; how do these things work exactly? What is the difference between "Batt" "Arm" and "Field"? and what else could have gone wrong inside this thing? I am trying to understand the electrics here. Feel free to tell it to me like I am a 2 year old. Thanks again for all you help!
--Rob
Rob
09-15-2005 03:29:04
 Re: Voltage regulator woes resolved in reply to Rob N VA, 09-14-2005 18:51:41
There is a good explanation in the FO-4 at paragraphs 66 & 67. It will teach you how to set it up to the voltages you want.
Dell (WA)
09-14-2005 22:15:19
Rob..... ...theres just TOO-MUCH to school you on how a voltage regulator works for the N-Board. Jim Cox, an occasional contributor and professional generator rebuilder had a very excellent web-page on voltage regulator theory. Do a N-Board search.
The BATT & ARM terminals are part of the internal cutt-outt relay scheme that disconnects the genny from the battery when the engine stops so you don't drain the battery overnite. And conversely, the cutt-outt relay connects the genny to charge the battery when the engine is turning the genny. The cutt-outt relay MUST BE POLARIZED to match yer battery polarity and genny volts polarity.
The genny field is a DC electo-magnet whose strength is varried by a vibrating voltage sensing relay. The strength of the magnetic field governs the genny AMPS OUTPUT which charges the battery.
Ford also uses a seperate ground wire to provide "zero-volts" ground difference between the voltage regulator and the generator. Alotta gennys/VR's depend upon engine iron to provide the common ground and neglect the effect of rusty joints on voltage drops. Ford's ground wire doesn't.
As to yer voltage regulator problem, NOTICE the cutt-outt relay is 2-seperate wire coils and I would suspect that the finewire coil is OPEN..... ...Dell
Rob N VA
09-15-2005 02:58:21
 Re: Voltage regulator woes resolved in reply to Dell (WA), 09-14-2005 22:15:19
Thanks a lot Dell, that clears up alot of the mystery. I appreciate you taking the time to answer some of my questions. ---Rob
