Order Ford 8N Parts Online
Carb 8n
Rob n VA
09-30-2005 17:58:54
After my follies with the manifold replacement (see previous posts) When i went to put the old carb back on the new manifold, I ran into problems. First off I had to replace the carb to manifold nuts, cause some fool had used brass nuts. I replaced the nuts and installed the carb and turned on the gas. Fuel promptly ran out the throat of the carb. I figured the needle valve and seat were gunked up, BUT WHY??? This thing was running pretty good when i started this project. When I started it up it ran very poorly. The govonor was "pulsing" the carb to gov rod back and forth. What causes that? It also seemed like it didn't want to get up to its full RPMs. I have no tachometer so I am going by ear. Do you guys have any suggestions before i dive into the carb in the morning? Thanks again!---Rob
old
09-30-2005 18:33:41
 Re: Carb 8n in reply to Rob n VA, 09-30-2005 17:58:54
Seen that over and over again. First thing I'd do is with the gas on tap on the carb. You may have some junk stuck in the float needle seat. Also you may have a bad float or stuck float happens all the time
