Order Ford 8N Parts Online
8n no spark
BADDAD
10-05-2005 16:44:45
i have a old 8n han spark but lost it dont quite know how this unit is supposed to work any good reading on the topic. old as in 1930-50 looking for dist data
Bruce (VA)
10-05-2005 16:49:50
 Re: 8n no spark in reply to BADDAD, 10-05-2005 16:44:45
Lot's of folks here will be glad to help, but you need to give us some more info. Is the distributor on the front of the engine or on the side, and is it a 6v or 12v? When was the last time it ran and what were the symptoms when it stopped?
souNdguy
10-05-2005 16:48:25
Narrow it down a bit further. does it have a front mount distrib ( 4 nipple cap ) or a side mount distrib ( 5 nipple cap ).
When is the last time you changed the points?
try hot wireing the coil.. that is a jumper wire from the battery to the coil input. see if that helps.
If not, post back which distrib you have and we will give you specific diagnostic info.
also state if 6 or 12v and positive or negative ground... points or electronic converted ignition.
Soundguy
BADDAD
10-06-2005 04:13:36
 Re: 8n no spark in reply to souNdguy, 10-05-2005 16:48:25
THE SYSTOM IS 12V HAS DIST ON FRONT. BELIVE IT OR NOT THIS ENGINE IS ON A WOODSPLITER I INHEIRETED I HAD IT RUNNING THEN TOOK OFF THE CARB FOR CLEANING ONCE BACK TOGATHER IT LOST SPARK THE POINTS LOOK GOOD.WHERE THE COIL STICKS INTO THE THE OPENING UNDER THE CAP A SMALL WIRE COIL TOUCHES THE SCREW THE CONDENSER AND THE POINTS HOOK TO THEESE SEEM TO BE TIGHT UNDER THE SCREW BUT THE SCREW SEEMS TO BE LOOSE AND IN LIMBO WHEN I RUN POWER TO THE COIL SOME TIMES THERE IS POWER TO THE POINTS AND SOMETIMES NOT BUT THE COIL SEEMS TO BE WORKING AS THERE IS JUICE TO THE WIRE PRONG STICKING OUT THE COIL
SORRY FOR THE CAPS DIDNT NOTICE
souNdguy
10-06-2005 04:50:47
 Re: 8n no spark in reply to BADDAD, 10-06-2005 04:13:36
Need to get that loose screw fixed. if you are having power show up 'now and then', and that screw is loose.. it is a likely suspect.
I believe Dell has the part number for that points hold down screw.. or at least the dimensions so you can get a replacement.
Gonna have to correct that first before youcan do any more troubleshooting. That may be the only problem anyway.
Here's a quote from a post by listmember Dell: lists pointsscrew dimension and P/N:
>those #8-32 X 3/16 points screws work >themselves loose eazily. Also they're plated >brass and wear eazily and don't hold well >eather. New points screw (50c cheap) are good >idea on old tractors. And while donb carries >them, so does your local FORD AUTOMOBILE dealer >parts counter. They're shorter than common and >come with built-in lockwasher. p/n 355047-S7 >
>(#8-32 X 0.19)..... ..Dell
Soundguy
