Still sanding away
Rob N VA
10-30-2005 14:59:02
This hood and front end paint job are really getting involved!! Might not be too bad for someone who is really good at bodywork. Today I pulled the hood and doglegs, and grill off. WHAT A MESS! The doglegs and grill are beyond repair, and I was wondering what the difference is in the restoration quality grill, vs. the cheaper model? Also, is the radiator supposed to bolted at the bottom, or is it supposed to just sit there? I am gonna try to get some snap shots for ya'll. ---Rob
old
10-30-2005 15:28:46
 Re: Still sanding away in reply to Rob N VA, 10-30-2005 14:59:02
The rad should have 2 bolts at the bottom and nothing else. The top is held in place by the upper rad hose. As far as painting I'd get an acid primmer for your first coat of primmer then the next coat should be just a plan old primmer. The acid primmer sort of melts its way in to the metal so you have less problems with the paint not sticking as it should.
