BOB, Since you have a Sun Scope it would be interesting to see the test results of some of those 6 V coils (side mount)that have +ve and -ve markings. The large number of PPL having problems with Condensers suggests that those coils (+ve & -Ve) have the secondary common connected to the +ve side of the primary. This places the condenser across the secondary if that connection is made to the dist, which most pll do if they have a positive ground. I have tested (using Current measurements) all the "original" N type coils and found that the "Battery" connection is the common connected to the secondary (this is correct by theory) and places the condenser in the primary circuit of a positive ground system. All of the automotive coils that I Tested have the +ve term connected to the secondary, which means they are meant to be used in a negative ground system. I would be nice to have some scope readings of those coils. Theory suggests that the trailing edge will be most affected, if the secondary common is connected to the Dist side. On the practical side if I was having condenser problems on a side mount dist, that had +ve & -ve marking, I would connect the +ve term of the coil to the battery and change the ground connection of the Battery to Negative (re-polarizing the Gen). Regards,
