2N Hydraulics -The fun begins!
B Little
04-26-2006 20:57:33
third party image
Well decided to tear into the old gal this eveing and this what I found. I appears someone must have attempted to pull the lift cylinder housing without disconnecting the control valve form the linkage first. Found the spring and broken rod in the bottom on the drain plug. So I justy tore it on down because there was also about two inches of water in the bottom and the control valve was stuck in the pump housing.
B Little
04-27-2006 22:00:16
 Re: 2N Hydraulics -The fun begins! in reply to B Little, 04-26-2006 20:57:33
third party image
I'm not sure what it's called officially. My uncle called it rooster comb, it's part of the three point center link assembly. It has a V shaped bracket that hooks into which ever notch you select and the chains that go down to the lower bars. I think to control lowest point when the hydraulics are lowered. I personally have never had the opportunity to use it since the Hyd. system was down when I got the tractor from him.
shannon from ohio
04-27-2006 01:19:18
Yery detailed photo though. Good job. As bad as my sight is sometimes a large photo helps??
B Little
04-26-2006 21:02:35
third party image
Sorry about that last photo being so large. Heres another.
Ford MAn
04-27-2006 05:22:52
 Re: 2N Hydraulics -The fun begins! in reply to B Little, 04-26-2006 21:02:35
What"s the lever on your left brake pedal ?
Something for a person with limited use of their legs ?
Also what it the ratchet looking thing on the floor next to your right brake pedal ?
Just curious .
Gaspump
04-27-2006 10:49:14
 Re: 2N Hydraulics -The fun begins! in reply to Ford MAn, 04-27-2006 05:22:52
Got the left hand brake lever on my 2N too. It's the Sherman built lever for hand operation of the left brake. Really assists anyone when the left foot is fethering the clutch and you badly need some left brake.
Ford Man
04-27-2006 05:25:49
I took another look at the pic and realized that was not your right brake pedal on the floor.
What I should have asked is what is the ratchet looking thing on the floor behind the tractor.
