Selenoid Question
barry 1950 8N
05-25-2006 03:52:20
How do I test a selenoid on an original 6 volt starter /front mount dist. 1950 8N ?
Thanks/ B-VT
Barry 1950 8N
05-25-2006 07:11:46
 Re: Selenoid Question in reply to barry 1950 8N, 05-25-2006 03:52:20
Bob / SouNdguy -Thank you!
If u don't hear from me again, the black flys carried me off.
Bob
05-25-2006 07:04:37
Connecting the battery to the correct stud is imperative for it to work.
Third Party Image
souNdguy
05-25-2006 05:48:42
Grounding the 3rd small terminal, should make the two big lugs common.
So you need a battery, and 3 test clip/wires, and an VOM meter or test lamp. Commect one test clamp from the base of the solenoid to battery ground, connect the other test clamp to the big lub that the batter hooks to. this is the one on the 'right' side of the solenoid, if the little terminal was facing away from you. now, hook your test lamp from the other big lug to battery ground.. no lamp should be on. now jumper the 3rd terminal to ground.. lamp shoul light up. To use a vom, connect it the same way and choose a votlage setting.. when you jumper the 3rd terminal, vom should show battery volts..
This isn't load test.. but you can do that with the starter itself..
Soundguy
