Ferguson System
BLittle
05-28-2006 12:54:06
If the center link spring was replaced by a solid tube to eliminate movement of the hydraulic control valve by the ferguson linkage, shouldn't you have height control by position of the draft lever?
ZANE
05-28-2006 19:39:21
 Re: Ferguson System in reply to BLittle, 05-28-2006 12:54:06
No. You can only have position control on the Ferguson system lift by installing one of my ZANE THANG POSITION/HEIGHT control devices.
See the link below for more information.
Zane
BillM (OH)
05-28-2006 15:58:07
I'd put some weight on the drawbar (hay trailer front loaded,etc.) with no top link connection and try it first. It's pretty touchy and will probably want to go all down or all up without any feedback from the top link at all. The top link on the brush hog is usually not holding anything when hogging and you still need limiter chains to keep it where you want it.
souNdguy
05-28-2006 15:10:36
Negative presure on the toplink would still pull the toplink 'out' and thus signal the hyds that the implement was encountering higher draft, and thus the hyds would try to lift the implement. I see what you are getting at, and yes.. if you coul immobolize the toplink rocker so that it didn't transmit pressure onto the draft linkage, it should function very similar to a position control.. But that draft plunger would have to be fixed solid etc..
Soundguy
