Cotter pins on bottom of oil pan?
rob 8N11071 KS
05-14-2001 06:50:29
What is the cotter pin drain thing on the bottom of the compartment just in front of the transmission? On the underside, this is just in front of forward tranny fluid drain. It looks like there's on in the pan too.
Do these actually seal to hold the oil in?
Salmoneye
05-14-2001 07:12:19
 Re: cotter pins on bottom of oil pan? in reply to rob 8N11071 KS , 05-14-2001 06:50:29
Exact opposite of sealing.
The cotter pins are there to keep those 'weep' holes open. The weep holes are there in case the front seal on the tranny or the rear seal on the engine leak fluid. They are not in the reservoirs themselves but between the engine and tranny...
Claus
05-14-2001 07:09:56
Just the opposite. They are there to let oil out.. The cotter key helps keep the hole open...
Happy Motoring
Claus
