Removing crankshaft ratchet
rob 8N11071 KS
05-14-2001 06:52:22
How does one remove the crankshaft ratchet? What size socket is that? I'd prefer not to have to pull the whole crankshaft.
JW(oh)
05-14-2001 10:02:53
 Re: removing crankshaft ratchet in reply to rob 8N11071 KS , 05-14-2001 06:52:22
Rob;
On my 2N the crankshaft ratchet took a 1 3/8" socket. I used an impact wrench and had no trouble with the crankshaft turning.
Thanks
Jeff
Jim
05-14-2001 08:54:45
Rob
If I remember it is a 1 and 5/16 inch socket. I could only get it in 3/4 inch drive. Pricy for just 15 seconds of work. If you can loan one from a neighbor.
Jim
rob 8N11071 KS
05-14-2001 09:03:53
 Re: Re: removing crankshaft ratchet in reply to Jim, 05-14-2001 08:54:45
Well, one more chance to get back what I put into my 3/4" socket set that I bought for hub nuts.
Any hints to preventing the crank from turning? I was just going to lodge a piece of wood in there.
Dell (WA)
05-14-2001 11:37:40
 Re: Re: Re: removing crankshaft ratchet in reply to rob 8N11071 KS , 05-14-2001 09:03:53
Stuff one end of a long soft rope into any sparkplug hole and the piston will run up against the rope and you will have all the purchase you need to un-torque your crankshaft pully bolt with a 1 5/16 socket..... .Dell
Jim
05-14-2001 09:33:45
What is the condition of the rest of the engine. Is this the only part coming off? Is the engine still on the tractor? Is the pan off?
Many ways, but descibe you situation first.
Jim
rob 8N11071 KS
05-14-2001 09:38:32
 Re: Re: Re: Re: removing crankshaft ratchet in reply to Jim, 05-14-2001 09:33:45
It's off the tractor. The pan is off. I am replacing the engine.
Jim
05-14-2001 10:32:10
 Re: Re: Re: Re: Re: removing crankshaft ratchet in reply to rob 8N11071 KS , 05-14-2001 09:38:32
Rob
Put a piece of 2X4 between the crank throw and block and it should break free fairly easily
Jim
rob 8N11071 KS
05-14-2001 07:39:23
2N 6319 Ratchet (crankshaft)
holds on
2N 6312 Crankshaft (pulley)
crankshaft ratchet? bj/8N/mt----ntxt
05-14-2001 07:31:32
