Order Ford 9N Parts Online
NEED HELP LOSING POWER ON 9N
BAMABEDDING
09-19-2006 12:07:02
9N RUNS GREAT TILL I HOOK UP DISE OR BUSH HOG CANT GET OUT 1ST GEAR RUNS VERY SLOW IF IT GOES DEAD IT TAKE ABOUT 30 MIN TO START AGAIN COULD THIS BE THE POINTS IT HAS NEW ONES IN IT WHAT WOULD YOU SET THEM AT ARE DO THINK IT COULD BE A FUEL PROBLEM CARB HAS BEEN REBUILD THANKS FOR ANY HELP TRYING TO GET ARE FIELDS DONE FOR HUNTING
Roland (AL)
09-19-2006 13:43:46
 Re: NEED HELP LOSING POWER ON 9N in reply to BAMABEDDING, 09-19-2006 12:07:02
Where you located Bamabadding?
Later Roland (AL)
BAMABEDDING
09-19-2006 14:06:54
 Re: NEED HELP LOSING POWER ON 9N in reply to Roland (AL), 09-19-2006 13:43:46
TUSCALOOSA
Roland (AL)
09-19-2006 17:41:44
 Re: NEED HELP LOSING POWER ON 9N in reply to BAMABEDDING, 09-19-2006 14:06:54
I'm in Jackson just south of you on Hy 43. Old gave you good advice. Points must be set at .15-.17 to run there best ( .15 is the setting I set to .17 to cover for wear to the tab). Also make sure you have good gas flow through the carb. by takeing the plug out of the bottom of the carb. Breather clean . Good luck with the tractor and let us know the out come and you can get more help from the great group here.
Later Roland (AL)
BAMABEDDING
09-20-2006 08:27:23
 Re: NEED HELP LOSING POWER ON 9N in reply to Roland (AL), 09-19-2006 17:41:44
GOT EVERYTHING TO TUNE IT UP WITH I GOT MORE THINGS THEN I NEED TRACTOR IS AT HUNTING CLUB TO FAR TO BE RUNNING BACK TO TOWN FOR GOING TO WORK ON IT THURSDAY WILL LET YOU KNOW HOW IT WORKS OUT THANKS ROLL TIDE
old
09-19-2006 13:06:05
Points need to be set at .015. You need to check a few things also. Like how good is the spark?? It needs to be a brite blue spark not a yellow looking spark. Also when its running does chokeing it help or hurt the way it runs. If it helps then its either weak spark or the carb set to lean.
BAMABEDDING
09-19-2006 15:04:31
 Re: NEED HELP LOSING POWER ON 9N in reply to old, 09-19-2006 13:06:05
SORRY TO SOUND DUMB BUT IF THE SPARK IS NOT BRITE BLUE ITS THE POINTS RIGHT WOULD YOU ALSO REPLACE THE COIL
old
09-19-2006 15:50:20
 Re: NEED HELP LOSING POWER ON 9N in reply to BAMABEDDING, 09-19-2006 15:04:31
I'd start out with the points and then if you still don't have a brite blue spark maybe the coil. Other things that could be causeing you trouble would be a resister going bad or a condenser going bad
BAMABEDDING
09-19-2006 14:19:41
ITS 12VOLTS STILL SET AT 15 OR 20
old
09-19-2006 14:24:56
 Re: NEED HELP LOSING POWER ON 9N in reply to BAMABEDDING, 09-19-2006 14:19:41
Points need to be set at .015 or it messes with the timeing a little. As far as if its 6 volt or 12 volt that doesn't matter as far as the problem your haveing. What does matter it how good or bad the spark is and if its running to rich or to lean
