Steel/aluminum timing gear cover
rob-ks
09-23-2006 20:25:50
Can a guy swap them? The side cover, governor mount. Does the steel cover off a front-mount bolt up that same fit as the aluminum cover on a "52?
Hobo,NC
09-24-2006 07:57:42
 Re: Steel/aluminum timing gear cover in reply to rob-ks, 09-23-2006 20:25:50
No a steel cover will not bolt to a aluminum cover. Only front mount parts will werk with a front mount cover, same with side mount parts. Front mount gaskets are also pacific to Ft. Mt cover, same with the side mount covers. I think the rear cover to block gasket izz the same and all the Gov. to cover gaskets are the same.
souNdguy
09-23-2006 22:15:19
According to what I see ( someone correct me if'n I'm wrong ).
front mung gov plate is 9n6017 part number
side mount plate is 8n6017
They look nearly identical.. but not 100%. I assume thay are not swapable.
soundguy
