Order Ford 8N Parts Online
8n Manifold
Rob Mo.
05-21-2001 09:46:41
Got an 8n that leaks around the #4 cylinder. Do 8n's have a history of manifolds warping?
raytasch
05-21-2001 10:05:03
 Re: 8n Manifold in reply to Rob Mo., 05-21-2001 09:46:41
It is very common to see Ns leaking in the area of #4 cylinder. If caught early enough, the mating surfaces cleaned and new gaskets installed the manifold may stop leaking. If left leaking too long it can cause the block to etch/burn and become a larger problem. When you remove the manifold run a straight edge across the mating surface and see if is burned in the area it is leaking. New manifolds are cheap. ray
