Mechanics/Safety wire on oil pump
rob 8N11071 KS
05-23-2001 20:44:00
I am not familiar with how to properly attach safety wire to the flat head nuts that hold the cover on my oil pump.
Where can I buy safety wire (if that's what it's called in the store) and how is it properly attached?
Rod MI
05-23-2001 23:28:29
 Re: Mechanics/Safety wire on oil pump in reply to rob 8N11071 KS , 05-23-2001 20:44:00
rob first you have to drill a hole in each bolt then go to the hard ware store and buy sum wire then cut a piece of and put it threw the bolt at about center point then bend the wire in half take your pliers and twist it until you are close to the other bolt then thread the wire threw the other bolt then twist the end agene leave a 1/4 inch or sow then cut off the rest then bend the tab over sow you don’t cut your self this is the easiest way there is slightly better ways but with out showing you it would be hard for me to explain and I’m assuming you have two bolts good luck rod
rob 8N11071 KS
05-24-2001 06:30:24
 Re: Re: Mechanics/Safety wire on oil pump in reply to Rod MI, 05-23-2001 23:28:29
The nuts are already drilled. They had safety wire in them already.
Big Mike
05-23-2001 22:57:37
Stainless steel welding wire will work its available in rolls with .025 diameter.kinda expensive though. Most motorcycle shops carry small saftey wire kits.
rob 8N11071 KS
05-24-2001 06:31:11
 Re: Re: Mechanics/Safety wire on oil pump in reply to Big Mike, 05-23-2001 22:57:37
I have plenty of flux-core .35 wire. Will that work?
8NRay
05-23-2001 21:33:46
If there is an airport near you, stop at any shop
on the airfield and ask. They will know where you
can pick up a spool of safety wire. Most aviation
supply places carry it, as is standard fare on
aircraft.
