Oil Pump pickup tube
rob 8N11071 KS
05-25-2001 07:14:25
The pickup tube on my oil pump is loose and needs to be replaced (from what I read here).
When I get a new one, is friction fit enough? How should I attach it to the oil pump housing? The archives suggest silver solder, epoxy, and brazing. I think the oil pump cover plate is cast iron? Anything special I need to know about soldering the new one into place?
8NRay
05-25-2001 12:19:22
 Re: Oil Pump pickup tube in reply to rob 8N11071 KS , 05-25-2001 07:14:25
I agree with Salmoneye, either silver solder or braze your old tube back on. Whether it comes off again is a factor of how well it's put on, not how old it is. If you fear not being able to do a good job, take it to a welding shop and let them do it, can't imagine that being very expensive. Sure better than spending $150. Make the check out to me for $0.02.
Salmoneye
05-25-2001 08:06:35
I would sure as heck try and solder the one you have back together first before paying $150...
rob 8N11071 KS
05-25-2001 08:14:23
 Re: Re: Oil Pump pickup tube in reply to Salmoneye, 05-25-2001 08:06:35
If you read the stories in the archives about the horror of a tube falling off while the tractor is running, I am not so sure.
Anyway, at this point the N's been down for a month and a half. I need my tractor running again.
rob 8N11071 KS --- sorta answering the question myself
05-25-2001 07:39:18
I should have called the local dealer before I posted -- apparently the cover plate and pickup tube are sold as one assembly.
Sticker shock: $150
Mark *8N126975*
05-25-2001 09:46:22
 Re: Re: Oil Pump pickup tube in reply to rob 8N11071 KS --- sorta answering the question myself, 05-25-2001 07:39:18
I haven't come across anything yet that J&B weld won't bond for keeps. The guy that told me about it used it to weld an engine block on an old chevy truck. That was 5 years ago and he still drives it.
Old George
05-26-2001 05:03:37
 Re: Re: Re: Oil Pump pickup tube in reply to Mark *8N126975*, 05-25-2001 09:46:22
Mark, not to argue, but for jbweld to work correctly requires a clean surface. That is not likely on a part that is in the bottom of a n crankcase. FWIW
Alan Esch
45 2N kit 183513
