Order Ford 8N Parts Online
'51 8N connect the dots
Rob G
12-10-2006 18:53:21
third party image
I need help finishing the wiring on my '51 8N side mount distributor. I still need to wire up the alternator, coil, and ammeter. I greatly appreciate it if you can help me connect the dots. Many thanks.
Bob
12-10-2006 21:09:50
 Neil R's diagram... in reply to Rob G, 12-10-2006 18:53:21
There's no need to "re-invent the wheel"... here's a diagram that's been around for a while:
Third Party Image
If you are determined to use the (goofy) one-wire alternator, simply OMIT the #1 and #2 terminals on the alternator, and their associated wiring.
Consider the wire connected to the coil as connected to the coil's (+) terminal, and connect the (not shown) (-) terminal to the distributor.
OR ditch the "one wire" alternator, and get a STANDARD 3-wire alternator, and connect it up as shown in the diagram. A diode can be substituted for the "marker light", if you don't want an "idiot light" or the hassle of mounting it.
Rob G
12-10-2006 21:16:39
 Re: Neil R's diagram... in reply to Bob, 12-10-2006 21:09:50
Hey thanks. What's the detail on the ammeter? Is it a pass thru from one terminal to the other or everything wired on the same post?
Bob
12-10-2006 21:40:41
 Re: Neil R's diagram... in reply to Rob G, 12-10-2006 21:16:39
If you have an original induction ammeter, it will have a loop on the back that the wire from the solenoid to the terminal block simply passes through. If you have a shunt-type ammeter, it will have 2 terminals. If it happens to read backwards, swap the wires from between the 2 terminals.
(If you have an induction ammeter, and it reads backwards, reverse the direction in which the wire passes through the loop.)
Phil (NJ,AZ,Sask)
12-10-2006 20:25:43
 Re: '51 8N connect the dots in reply to Rob G, 12-10-2006 18:53:21
F to A, G to B, B to D, C to H
Should work,
Rob G
12-10-2006 20:44:25
 Re: '51 8N connect the dots in reply to Phil (NJ,AZ,Sask), 12-10-2006 20:25:43
Thanks. Have you wired one up this way before?
Phil (Nj,Az,Sask)
12-10-2006 21:48:37
 Re: '51 8N connect the dots in reply to Rob G, 12-10-2006 20:44:25
Nope! I wouldn't convert to 12V unless I had a 12 Volt reason.
BTW: You could wire G to D (instead of G to B)
and that would "physically" make D the Battery load center for lights etc. B & D are the same potential electrically but it just makes it easy to understand.
Note: The Ammeter may be incorrectly marked but
that does not harm the ammeter and can be corrected (swap A & B) if its reversed.
Hobo,NC
12-10-2006 19:06:12
I just let a blown fuse on a 98 jeep kick my buttttt tt so iffin yer luck'e Bob or a few utter lectrical smart guys will fix ya rite up.
BTW the first thang I checked wuz the turn siginal fuse and the last thang i checked after a day of werk'in on it wuz the fuse and it wuz bad. I am run'in with my tail tween my legs rite now.
Stumpalump
12-10-2006 19:18:16
 Re: '51 8N connect the dots in reply to Hobo,NC, 12-10-2006 19:06:12
Hobo I got a 98 jeep. What fuse kicked your butt. If I don't ask it will kick mine next.
