Order Ford 8N Parts Online
8N Governor with Tach
B. Jones
01-11-2007 10:15:14
My step father bought a new cable for his 1952 8n and when he went to install it he noticed that there was no place to screw it on the governor. Someone put an old type governor on his tractor. I notice that E-bay sells a case (Shell) for the cable hook up. Would the tractor also need new internal parts in order to make it work? I have not taken it apart yet to check out the insides. Thanks, B. Jones
Hobo,NC
01-11-2007 11:33:38
 Re: 8N Governor with Tach in reply to B. Jones, 01-11-2007 10:15:14
Remove the governor, remove the screw that holds the guts in, look at the end of the shaft and if it hollow I have the bush’in to install to drive the cable or make one out of a roll pin. Then all you will need izz the houshing made for a proof meter. Most of the gov. shafts have the provision for the drive pin wither for a proof meter are not.
Bob
01-11-2007 10:37:58
Better have a look in there. There's no telling what may have been cobbled together over 50+ years!
