Idle too fast
rob 8N11071 KS
05-29-2001 20:46:29
My N has always had a fast idle. I decided to fix it, finally.
I took the governor apart for a rebuild and going by Don8NAZ's rebuild instructions it didn't need it.
The engine is responsive at all throttle ranges. I can get a good idle if I back the idle speed adjustment screw out ALL the way and push forward about 1/4" on the governor outer arm. This pulls the throttle lever forward on the carb and gets the idle down to where it should be.
The problem is, there's enough play in the throttle lever and its linkage to the governor that as soon as I take pressure off the outer lever, the engine revs back up. If I push forward on the outer governor lever to get the idle down, the spring expands. Does this mean it's preloaded?
Ideas?
bg
05-29-2001 22:25:00
 Re: Idle too fast in reply to rob 8N11071 KS , 05-29-2001 20:46:29
Is the spring hooked up from the tab on the flywheel hosuing to the throttle arm at the bottom of the dash?
rob 8N11071 KS
05-30-2001 06:30:09
 Re: Re: Idle too fast in reply to bg, 05-29-2001 22:25:00
I believe so, yes. I'll double check. I know there is tension on the throttle because my quadrant plate is worn and sometimes it springs back.
