NO QUESTION, the round-can coils are better. (I can just HEAR the purists gagging about now!) You mention A lead from the coil to the distributor... there will be TWO. A wire from the (-) terminal on the coil (assuming the battery is connected (-) ground)has to go to the points and condensor INSIDE the distributor. There is a special brass screw down inside the distributor that the coiled "spring thingy" on the OEM coil matched up with to make that connection, and that's where the PRIMARY connection from the round-can coil needs to go. The high-tension tower on the "new" coil has to connect to a little "button" facing upward on the distributor cap, where the high-tension tab on the OEM coil used to "sit". In the past, I have done a couple of these conversions. I fastened a "high tension tower" cut from an old automotive distributor cap to the high-tension "button" on the "N"'s distributor cap, then use a fiberglas repair kit to mold it into place. Then, I trimmed a small piece of sheet steel to match the open top of the distributor, and drilled and tapped two small holes to fasten it to the top of the distributor housing. Then, I drilled a small hole in the housing for the wire from the points/condensor to exit the distributor, and sealed the wire in place with a dab of silicone sealant. Others have "gutted out" the windings, core, and "tar" from an old square-can coil, and connected the wires from the new coil down inside the "gutted out" old coil. Doing that covers the distributor, but puts another set of possibly troubleome connections... the coiled spring, and the spring tab back into the circuit. Pertronix makes a adapter to do the same thing as the "gutted out" coil. I'm not sure if you can buy them separately, or just with a Pertronix electronic ignition. I hope all this RAMBLING helps a bit!
