Plug wires
awadi
02-17-2007 10:19:13
Need some advice on plug wires, 47 8n front mt dist.
Went to the local ford tractor dealer and he wanted $44.00 for a set, but had a set made in India for $12.00. Came home without nothin. Would like to buy a good set but $44 seems too much, What price should a good copper set cost and any idea on where to get them.? thanks, you guys got more knowledge than britinnaca.
Skyhawk Greg
02-18-2007 19:29:32
 Re: Plug wires in reply to awadi, 02-17-2007 10:19:13
Dan - Another thing that I find useful, is to not only check the wires at night, but to take a spray bottle and coat the wires with water mist while running. This enhances any imperfections. Greg
Ross Pugh(NC)
02-18-2007 04:08:40
Exactly like original about 2 years ago at Dennis Carpenter=$21.50 a set. Probabaly not gone up to $44.00 yet.
Tm N MS
02-17-2007 17:10:45
You made a good choice. Obvious thieves in that business. I'd never slow down when going by there much less go in..
Wisconsin Cowman
02-17-2007 11:14:16
Just go to your local farm store and get them there.
Wisconsin Cowman
02-17-2007 11:14:11
don b
02-17-2007 10:28:54
Awadi..... .14.50 gets you a nice set of copper core, silicon rubber,with weather heads,pre-cut to exact length.Email me if you can't find this bargin on this board. don b
awadi
02-17-2007 10:40:13
 Re: Plug wires in reply to don b, 02-17-2007 10:28:54
Thanks, I didn't know what it took, but theses are aol farm tractors and built to be worked on easily. I think I will buy the $39.99 complete tuneup on this site, wires,plugs etc. proably be the best deal. I think this ole 8n is gonna run again and be pretty, this is a great board.
RP-40-9n
02-17-2007 10:27:59
awadi, price 12 to 15 dollars. call the older parts stores in your area, and tell them you want metal core wires for older tractor. i get mine at car quest, they come allsize, meaning extra length, ends and wires not attached so you can custom fit any size you need. RP
Bob
02-17-2007 10:27:30
What did the $12.00 set look and feel like?
It doesn't take anything REAL high-tech for these tractors, so long as the wires are wire-core.
dan hill
02-18-2007 05:17:26
 Re: Plug wires in reply to Bob, 02-17-2007 10:27:30
I think many ignition wires are replaced without good reason.Check them at night for leakage.The newer carbon core wires fail but the old solid wires will go on for a long time.Cracked insulation would be the only reason I would change them.
