Order Ford 8N Parts Online
8N Crankshaft bearing journals
BOB IN TN
03-04-2007 15:05:39
I recently bought a sidemount 8n that sqealed to high heaven when turned over. After teardown I noticed #2&3 rod journals were dry and 1&4, as well as mains, were not. As these are oiled through crank, my question is, is it possible for oil gallery obstruction, or is this common with failing oil pumps. Either way I'm rebuilding pump, but is there a way to insure proper crank oil flow. Thanks in advance.
