12 volt delco update
B. Jones
03-07-2007 18:34:33
Thank you Bob, SouNdguy, and Dell for posting about my alternator problem. Today I took off the diode and replaced it with a small dome light. I know it is less than 1 amp. It works great. Now when I shut the motor down the light comes on for about 6 to 8 seconds and goes off without the on off situation. Of course the fuel gauge goes to empty when the light goes out. I was afraid too much current was going through the pressure switch. I decided not to hook it to the starter switch even though it worked there also. To anyone else reading this post, it is a diesel and does not have an ignition switch. When the motor starts there is an oil pressure switch that sends power to make the fuel gauge work. Today I turned all the lights on and even at 800 rpm it was charging. With the old generator you had to have it at`1400 rpm to charge with the lights on. Again thanks guys.
Dell (WA)
03-07-2007 21:04:10
 Re: 12 volt delco update in reply to B. Jones, 03-07-2007 18:34:33
Jonesie..... .thanks for the feedback. Its good to learn what yer "fix" was and why..... ..Dell
Bob
03-07-2007 19:07:10
Good to hear!
