Dell, just a quick question
Rob8N
03-19-2007 04:29:15
Dell, my thermostat is in the top of the head not in the hose, would this temp be hotter?
Just a followup to my original post of how hot is too Hot. Thanks Dell.
souNdguy
03-19-2007 06:18:25
 Re: Dell, just a quick question in reply to Rob8N, 03-19-2007 04:29:15
Most of us use a hose clamp to hold the 8n thermostat int the hose about midway to the radiator.. however.. i'm confused by your statement that your theremo is in the head.. it shouldn't fit in the water outlet, assuming it is the correct thermostat.
Soundguy
8N'r--WI
03-19-2007 07:51:15
 Re: Dell, just a quick question in reply to souNdguy, 03-19-2007 06:18:25
Sounder--I'm glad I read this post. The 49 8N I am working on did not have a thermostat in it and I am putting my new one in tonite.
I was expecting that I would have to use a little force to slide the new one into the hose a bit, but after your comments about "securing" the thermostat with a hose clamp, I got to wondering.
Does the thermostat fit tight in the hose and is it necessary to use the hose clamp---any danger/potential problem if you don't?
I didnt put a hose clamp on my 51N either.
Thanks---Tim
JDrew
03-19-2007 08:24:52
 Hose Clamp for Thermostat in reply to 8N'r--WI, 03-19-2007 07:51:15
The thermostat is a tight fit when the hose is COLD. However, when things start heating up and the hose softens, the back pressure behind the thermostat will slide it up the hose to the radiator where it won't be in contact with any fluid until things get REALLY hot.
I had problems with overheating, but when I got the thermo held down at the head end, things improved greatly. (Still have problems, but that's another story...)
J-
8N'r--WI
03-19-2007 09:27:46
 Re: Hose Clamp for Thermostat in reply to JDrew, 03-19-2007 08:24:52
J---thanks for the response----I will buy another clamp---Tim
Ford 312
03-19-2007 07:19:46
I think he is talking about the heat sensing unit for his temperature guage, being in the head. This is what I conclude after reading this and his first post.
souNdguy
03-19-2007 07:30:58
 Re: Dell, just a quick question in reply to Ford 312, 03-19-2007 07:19:46
Hmm... big difference in thermostate, and a temp sender or bulb.. etc.. Especailly if he is asking for advice.. he needs to be real specific..
Soundguy
Ken S
03-19-2007 08:18:05
 Re: Dell, just a quick question in reply to souNdguy, 03-19-2007 07:30:58
He's only askin' for Dell's advice, which tell's me nobody else's advice is valid in his opinion. The hail with tryin to help him.
Dell (WA)
03-19-2007 06:15:42
third party image
Rob..... .iff'n yer engine don't look like this, it ain't an 8N or 9N or 2N. And the ONLY radiator thermostat is in the cylinder hose.
Now then the cyclops-eyed NAA Jubilee Red-Tiger OHV engine does have a replaceable cylinder head elbow and its thermostatic DISK mounts between the elbow and head..... ...Dell
Lance in Brenham, TX
03-19-2007 09:49:33
 Re: Dell, just a quick question in reply to Dell (WA), 03-19-2007 06:15:42
cylinder hose? I'm confused.
uh . . . Dell (WA)
03-19-2007 14:03:41
 Re: Dell, just a quick question in reply to Lance in Brenham, TX, 03-19-2007 09:49:33
Geeze..... .do I haffta post a picture of the cylinder head radiator hose too???? ..... ..respectfully, Dell
03-19-2007 17:43:29
 Re: Dell, just a quick question in reply to uh . . . Dell (WA), 03-19-2007 14:03:41
Oh, radiator hose, now your clickin' on all cylinders...pun intended!
bva
03-19-2007 15:57:22
Now I don't own one of them N's but I do have an NAA so that picture may come in handy . Now if you could extend some of your kindness.
