How loud are the delco remy alternators?
rob 8N11071 KS
06-08-2001 06:18:27
I just replaced mine because it was squealing.
The new one that came with the 12V conversion kit iw pretty darn loud. It doesn't sound like it's malfunctioning, but I never remember a car alternator being this loud. The new one has an ongoing WHIRRR. At idle, it's clearly the loudest component on the tractor.
I check for overtensioned belt and a belt that may be binding. It has the standard 1/2' deflection with moderate thumb pressure.
The belt appears straight, and the sound doesn't have a rhythym to it, so I don't think there's a flaw in the belt.
Makes me wish I hadn't bought a new muffler.
9N'er
06-08-2001 10:55:43
 Re: how loud are the delco remy alternators? in reply to rob 8N11071 KS , 06-08-2001 06:18:27
My delco alternator is loud. At idle, it is clearly the loudest whirring unit thing on the tractor.
Same at low speed or going down hills...thing just whirrrrr s to beat the band.
Seems typical of these units.
My Delco is loud, too!
06-08-2001 10:22:05
I also just bought a 12 volt conversion kit which includes a delco remy 12 v alternator, and I had a similar observation: the thing is kinda loud. Not, like, huge loud, but at idle, I can clearly hear it whirring. I aimed the deflector on my vertical exahust pipe so it points more at me, and now, I don't so much notice the wirring anymore.... But that alternator was louder that I expected.
rob 8N11071 KS
06-08-2001 10:25:48
 Re: Re: how loud are the delco remy alternators? in reply to My Delco is loud, too!, 06-08-2001 10:22:05
That's how I would describe it: "I can clearly hear it whirring." It doesn't make a scraping or grinding sound, just a whir.
But the whir is louder than I would expect.
rbell
06-08-2001 07:44:30
Shot in the dark, but place a bar of soap against the sides of the belt for a second while the motor is running (BECAREFUL) if the sound lessens, it is a belt
rob 8N11071 KS
06-08-2001 07:52:07
 Re: Re: how loud are the delco remy alternators? in reply to rbell, 06-08-2001 07:44:30
Against the outside of the belt? What does that do?
Jimp CO
06-08-2001 08:42:38
 Re: Re: Re: how loud are the delco remy alternators? in reply to rob 8N11071 KS , 06-08-2001 07:52:07
that is a poor mans way to lubricate a fan belt. It works too.
rbell
06-08-2001 10:23:52
 Re: Re: Re: Re: how loud are the delco remy alternators? in reply to Jimp CO, 06-08-2001 08:42:38
What you mean poor mans way? :-) Ok,OK, so I am poor, but it sure quiets a noisy belt. I have on a number of ocassions thought I was losing a bearing when it was just belt noise. Have a wonderful week end!
Jimp CO
06-08-2001 11:56:41
 Re: Re: Re: Re: Re: how loud are the delco remy alternators? in reply to rbell, 06-08-2001 10:23:52
Beats that $3.95 can of spray. I guess it's still that price.
Beekeeper
06-08-2001 06:51:00
Rob,
Mine is very quiet - no whirrrs.....
Perhaps you should consider getting a replacement from the company you ordered it from - it could be defective or the bearing could be a bit loose. Is it a rebuild? If so, then perhaps it was put together quickly and without Quality Assurance measures. I've had to return a lot of rebuilt autoparts over the years because of poor workmanship.
rob 8N11071 KS
06-08-2001 07:05:19
 Re: Re: how loud are the delco remy alternators? in reply to Beekeeper, 06-08-2001 06:51:00
I had it for a year before I installed it.
It came with the kit from Mikes Tractors. I don't know if they sell rebuilt or new, but I bet they are rebuilt.
9N Chuck in Mo
06-08-2001 06:38:05
Sounds strange, I have 12 volt system with AC/Delco alternator, not loud at all. I suppose, if it works, don't fix it.
