COLD AND DARK AND THE PTO SHAFT IS OUT
BILLC
02-04-2000 17:24:04
I HAVE THE TRACTOR IN A DITCH SO THE OIL WON'T RUN OUT, WHICH WAY DOES THE COLLAR AND SEAL COME OFF, TO THE FRONT SIDE OF THE SHAFT OR BACK, AND DO YOU HAVE TO POUND IT OFF OR SHOULD IT COME EASY? THANKS IN ADVANCE I,M IN TROUBLE
ZANE
02-04-2000 20:03:09
 Re: COLD AND DARK AND THE PTO SHAFT IS OUT in reply to BILLC, 02-04-2000 17:24:04
If you already have the pto shaft out of the tractor you can remove the snapring that is on the inside of the bearing hub.Forcefully drop the implement end of the pto shaft and hub down on a piece of solid hard wood a couple of times and the hub will fall off. Then you can knock out the seal from the inside out and then install the new seal before you put the hub back on the bearing.
If the shaft assembly is still in the tractor you can pull the seal out by fashioning a seal puller by welding a big sheet metal screw to the end of a steel rod and bend a 90 deg hook on the other end and before you put the screw into the edge of the seal you should put a large piece of pipe over the home make tool to use as a knocker and then you can jerk the seal out with the home make tool. If you have an impact tool for body work it is even better.Just weld a screw to a nut that will fit the impact tool threaded end. This way it is not necessary to pull the pto shaft to replace the seal.
Clarence Carhill
02-04-2000 18:53:50
Bill.... Take the four bolts out and pull the PTO shaft out. Sometimes they will come out hard and when they do I fixed up a hub puller to help. The PTO seal comes off the front end of the shaft. You will have to pry it out of the bearing cap. Make sure you put the new seal back in the right way around. It's rather a simple job.... "Good Luck"....
