1944 brake drums
rob-ks
08-03-2007 06:52:59
Anyone know the specs on a brake drum. Are these things ever turned? What is the minimum thickness?
I"m going to sell off a pair and I would like to know how to grade these drums. They look and worked fine but I would like to be able to say more than that.
I don"t know I can even measure the thickness because the mic won"t reach; maybe if I use some kind of spacer.
So any info on the specs would be appreciated.
Gaspump
08-03-2007 07:36:48
 Re: 1944 brake drums in reply to rob-ks, 08-03-2007 06:52:59
Not really thick enough to be turned. Could be dressed up if you can find a turner that will do it. Tractor turns pretty slow so new shoes usually wear in fine. If the drums are badly worn good ones are out there too.
