DRAFT POSITION EXPLANATION
BIGP
05-24-1999 07:04:34
CAN ANYONE OUT THERE GIVE A SIMPLE EXPLAINATION OF THE DRAFT/POSITION CONTROL LEVER ON MY 8N? WHICH POSITION SHOULD IT BE IN FOR BUSHHOG? WHAT POSITION FOR BOX BLADE?
Dell (WA)
05-24-1999 07:28:39
 Re: DRAFT POSITION EXPLANATION in reply to BIGP, 05-24-1999 07:04:34
BIGP..... ..the little handle under your right knee is the draft/position control. It is not for a "flush" (grin)
Forward/horizontal for draft control...as in plowing.
Up/vertical is for position control as in brush-hogging.
All N-tractor hydraulics are internally "sensed" for draft (load) and when the load exceeds the setting, the hydraulics "automagic-ically" lift the arms just a little bit or if the plow drag (load) lessens, it will allow the arms to lower a little bit and the "suck" of the plow will pull it a little deeper into the dirt. This draft action keeps a constant load on the tractor engine for maximum engine efficency.
Only the 8N has the option of position or draft control on the hydraulics.
I keep my 8N in positon control (up) for everything I use my tractor for.
Hope this helps..... ....Dell
Jim (OR)
05-27-1999 18:12:07
 Re: Re: DRAFT POSITION EXPLANATION in reply to Dell (WA), 05-24-1999 07:28:39
When the position control lever on my '51 8N is put in the horizontal position, the lift arms drop like lead baloons and I can't raise them with the touch control lever at all. IS THIS NORMAL?
Um...Dell?
05-24-1999 16:29:01
Would you concur that a good way to remember which position is for which task might be...
...forward (horizontal) for plowin', then up and rearward, toward the "over-running coupler", for hoggin'.
Keep 'em safe....
Jack S.
05-24-1999 18:26:44
 Re: Re: Re: DRAFT POSITION EXPLANATION in reply to Um...Dell?, 05-24-1999 16:29:01
Good tip Dell, how about Down-Draft-Digging (plowing)
