O.T. choosing the right tractor
Rob N VA
01-14-2008 14:58:28
The company I work for is trying to buy a tractor to haul around an 8000 pound boat/trailer. The tractor we choose also has to be able to launch the boat down a 10 degree slope boat ramp. I would love to tell my boss to let me bring in my ol" 8n but I think we need something a little more heavy duty :( We are also looking for something with a decent turning radius. I hate to ask on this forum, but if anyone can give me some good advise, it"s you fine folks here. Thanks alot!!
gahorN
01-14-2008 20:12:20
 Re: O.T. choosing the right tractor in reply to soundguy, 01-14-2008 14:58:28
Get a US built tractor. Which are those? Most John Deere's... see list below.
John Deere (johndeere.com)
Farm, Lawn & Garden Tractors
Most tractors built in North America. All large Ag Tractors (7000, 8000 and 9000 Series both tires or tracks) built in Waterloo, Iowa. 4000, 5000 Series, 790 & 990 as well as Advantage Series 5105 & 5205 built in Augusta, GA. Lawn & Garden Tractors built in Horicon, Wisconsin.
6000 Series built in Mannheim, Germany.
6403 & 6603 built Satillio Mexico. (per johndeere.com cust serv email 11-24-01) (Why not made in Saipan?)
Wanna find other products made in USA and not simply re-packaged / re-labelled foreign junk ?
http://www.usstuff.com/index.htm
soundguy
01-14-2008 17:24:56
 Re: O.T. choosing the right tractor in reply to Rob N VA, 01-14-2008 14:58:28
I'd go with a ford 4000 or 5000.
soundguy
Ultradog MN
01-14-2008 20:04:15
 Re: O.T. choosing the right tractor in reply to soundguy, 01-14-2008 17:24:56
Yes,
A 5000 with an SOS!
soundguy
01-15-2008 04:52:03
 Re: O.T. choosing the right tractor in reply to Ultradog MN, 01-14-2008 20:04:15
Yep.. and tie the traction disconnect down.
Double safety of the sos is if the trans failed while backing into the water.. the tractor would just lock and set there!
Either the 8spd or the 10 spd, and the larger tractor will make a much safer boat tender.. plus the 4000/5000 have better brakes.. and the weight to put the hp to use.. etc.
soundguy
soundguy
Rob N VA
01-15-2008 14:12:42
 Re: O.T. choosing the right tractor in reply to soundguy, 01-15-2008 04:52:03
What is SOS?
soundguy
01-16-2008 05:20:44
 Re: O.T. choosing the right tractor in reply to Rob N VA, 01-15-2008 14:12:42
Fords 10 speed transmission. came out around 1959 and went till about 75 i guess. Think of it as a 'power-shift' tranny. Select-O-Speed
Could have independent pto ( some models had 2 speed ), and 2 rev gears.
Earlt models were plauged with problems that more or less gave the trans a permanent black eye. Many were feild repaired or recalled, but the early problems coupled with the lack of knowledgable mechanics to repair them, in existance today, and parts becomming harder to find has relegated them to virtually 'hobbiest-support'. ( plenty of knowledgable people hear can help guide someone thru a diagnosis and repair if they have the sorrect manual.. however it's hard to find a mechanic that will work on them. if you do find one.. the price can be huge.. IE.. upwards of 2000$ or more. Thus the machines usually command less $ at sale than a similar with a gear trans.. like an 8spd... which is by comparison.. fairly bulletproof.
If you find a good running OS and it has been maintained well.. it generally will continue to run good as long as maintenance is kept up on it.. etc.
soundguy
Dell (WA)
01-14-2008 16:05:25
Rob..... ...for eaze of manuvering and launching put a FRONT HITCH on which ever vehicle you choose to use..... ..Dell
Sean (TX)
01-14-2008 15:20:27
 Re: O.T. choosing the right tractor in reply to john hunt, 01-14-2008 14:58:28
Why not a 1 ton truck? How far is the boat going to be hauled? Is that going to be its only purpose in life? (hauling a boat?
Jim SC
01-14-2008 15:19:00
I used my older N as a backup for a bigger tractor at our marina while repairs were being made. SCARY! With the tractors available today, I would suggest the following items:
1. 8000 lb boat = tractor in that weight range
2. Hydramatic transmission for quick manuvering (or at least syncro-shift)
3. R-4 tires for long wear
4. 4 wheel drive
5. Hitch attached to 3 point lift (a lifesaver)
There are lots of off brand tractors with good engines and starting reliability. You won't need power, you'll need braking, manuverability and reliability. (Experience talking here)
Jim SC
01-14-2008 15:27:28
 Re: O.T. choosing the right tractor in reply to Jim SC, 01-14-2008 15:19:00
Sorry...thought you were talking about more than one boat.
