OT- Ford Taurus
B. jones
01-27-2008 09:49:49
I know this is way off topic but you guys are really good with information. How much torque is required on the bolt that holds the vibration dampener on the end of the crankshaft. 3.0 vulcan engine (2 valve) 2002 model Ford Taurus. Should I use loctite on the threads? ( The big center bolt that is?)
b. jones
01-27-2008 18:43:17
 Re: OT- Ford Taurus in reply to B. jones, 01-27-2008 09:49:49
Thanks for the replies guys. I am addicted to this site and know that there is a wealth of information here. Again thanks.
Areo
01-27-2008 18:19:43
My Book for '86-95 Taurus specs. 141-169 for1990 and b4 and 107 for 1991 and later.
HTH
Areo
rustyj
01-27-2008 17:02:28
Check with a car mechanic. But, i just tighten things until i get them tight. If it is a large bolt, i don't think you will break it off with a large ratchet (1/2 inch drive)! If i'm using an air ratchet, i let it tighten the bolt until it stops turning, then shut off the tool! This problem is something you will have to learn by trial and error. Especially if you don't have the specs for how tight to make it.
Dunk
01-27-2008 17:07:57
 Re: OT- Ford Taurus in reply to rustyj, 01-27-2008 17:02:28
BARTENDER!!!
I'll have one of what rustyj, is having, maybe two!!
Dunk
01-27-2008 17:10:01
 Ford Taurus, Hobo, I Spec You Can Answer This. in reply to Dunk, 01-27-2008 17:07:57
Oh, Well!!!
