Order Ford 8N Parts Online
Ford 8N Starting Problem
Rob Bowman
03-08-2008 14:54:53
This message is a reply to an archived post by SONNY MARLER on June 06, 2003 at 07:20:56.
The original subject was "Ford 8N Starting Problem".
I just replaced the solonoid on my 8N. it cranks and attempts to start but will only stay running if I hold down the starter button.There is an electrical disconnect somewhere. Can you help.
Thanks
Dunk
03-09-2008 10:55:06
 Re: Ford 8N Starting Problem in reply to Ultradog MN, 03-08-2008 14:54:53
Rob Bowman said: (quoted from post at 14:20:26 03/09/08) Thanks for all your information. I have it hooked up like your "right" diagram indicates. Is it possible that I have the wrong solonoid or am I still missing something?
Maybe this will make it eaiser to understand what we are saying.
third party image
third party image
Rob Bowman
03-10-2008 16:48:56
 Re: Ford 8N Starting Problem in reply to Dunk, 03-09-2008 10:55:06
Thanks guys!
I got it!
Dunk, it took your colored diagram for me to see the light.
Thanks for being there.
Rob
Dunk
03-10-2008 16:52:09
 Re: Ford 8N Starting Problem in reply to Rob Bowman, 03-10-2008 16:48:56
Most times a picture IS worth a thousand words.
third party imagethird party imagethird party imagethird party image
Dunk
03-08-2008 16:11:19
 Re: Ford 8N Starting Problem in reply to Rob Bowman, 03-08-2008 14:54:53
In my "Right" diagram here, the wire that goes to the switch (or maybe to the junction block, is not shown, a smaller wire, about the size of the one that goes to the push button start switch) it hooks on the Bat side of the solenoid, NOT the starter side of the solenoid.
If it was on the starter side of the solenoid, it would cause the condition you posted about, the coil would only be hot when the starter was running.
third party image
Rob Bowman
03-09-2008 10:20:26
 Re: Ford 8N Starting Problem in reply to Dunk, 03-08-2008 16:11:19
Den N Ms
03-08-2008 15:57:54
As Dunk said,The correct solenoid has three terminal posts.You need to make sure that the wire from the battery and the wire going to the amp meter or your ignition switch are on the same post of the solenoid.
Dunk
03-08-2008 14:59:30
 Re: Ford 8N Starting Problem in reply to MikeT, 03-08-2008 14:54:53
Rob Bowman said: (quoted from post at 19:54:53 03/08/08) This message is a reply to an archived post by SONNY MARLER on June 06, 2003 at 07:20:56.
Thanks
If I understand this post... (I am not sure why we are replying to 2003 posts)
The wire from the solenoid to the switch is on the wrong side of the solenoid. It should be on the BAT side, not on the starter side.
Rob Bowman
03-08-2008 15:45:31
 Re: Ford 8N Starting Problem in reply to Dunk, 03-08-2008 14:59:30
the solonoid has only one lug to put the wire on. it looks just like the old one.
Rob Bowman
03-08-2008 15:41:01
The solonid has only one terminal. It looks just like the old. one
Rob Bowman
03-08-2008 15:47:48
 Re: Ford 8N Starting Problem in reply to Rob Bowman, 03-08-2008 15:41:01
sorry for the confusion on this post. I'm just learning how to use this.
